1971 Challenger,1970 Barracuda,1970 Challenger
Goto page Previous  1, 2, 3 ... 19, 20, 21
PostPosted: Sun Oct 12, 2014 8:34 pm    Post subject: Reply with quote
Da er begge bladfjører og alle foringer nye. Fikk et par timer med effektiv verkstedtid i dag også Very Happy
PostPosted: Sun Oct 12, 2014 8:54 pm    Post subject: Reply with quote
Dragracelager? Nytt for meg....en lærer vel litt etter hvert Laughing
Fikk et par timer jobb i dag. Skifta bladfjør,foringer,bolter sjakkel og U-bolter på venstre side. Fremre del av den gamle var bøygd av materialtrøtthet eller noe,så bilen var et par tommer lavere på den sida enn høgre. Neste fjør neste gang en får anlednng Wink
Tech Question
Shannon Fuller, Salisbury, Australia, 1970 Dodge Challenger 440
I'm a long time reader of MA and always enjoyed your tech articles. I have finally got a problem that hopefully you can help me with. On my '70 Dodge Challenger, I've had the Green Bearing kit installed by a local diff specialist, however, when I'm installing the drivers side (Left hand side) axle, it binds up as I'm about to finish tightening the retaining nuts and will not turn over. Any idea what the problem is here? Is the bearing installed in the wrong position or have I forgotten to put some kind of spacer in?
Thanks very much for your help!
Shannon, I see only three possibilities: Either one (or both) of the bearings wasn't pressed on all the way; or one (or both) of them are defective; or the thrust spacer (on clutch-type Sure Grip) has fallen out on one side and the axle is attempting to mangle it.
Of course, there's always the possibility of mismatched parts, but you ddn't mention swapping anything. In other words, if you're using axles which are too long for the housing (from a different body style, aftermarket ones cut too long, etc.)
By the way, you DO know that those Green ball bearings have MUCH less capacity than the stock Timken tapered roller bearings, and are recommended for straight-line (read: drag racing) use only?
Rick
Et lite utklipp fra Tech spaltene i MoPar Action.
Gøy og se at noen er flinke og får bilen i orden
K-E Very Happy Very Happy
PostPosted: Mon Oct 13, 2014 8:21 pm    Post subject: Reply with quote
Moro med progresjon i tråden, Andreas! Og så gøy med prøvetur og "skilter" på bilen. Håper du får sortert ut litt i vinter og har det meste klart til sommeren. Håper å møte deg med bilen snart Smile
PostPosted: Mon Oct 13, 2014 8:25 pm    Post subject: Reply with quote
Sjå der ja...
Takk for info Very Happy Spørs om en går for standard Timken på den akselen da. Blei green bearings på akselen som skal i 440-bilen.....Blir vel meir svingkjøring med 340 enn med 440 manuell Wink
Lillaen er satt opp for å ta svinger,med boxa bærearmer, groveste stabstag fra firm feel og polyforinger.
Har ett bakre stabstag liggende fra firm feel også....får trekke lodd eller "elle melle" kafor en bil det skal på. Har ett tilsvarende framre fra firm feel til 440-bilen.
PostPosted: Mon Oct 13, 2014 8:36 pm    Post subject: Reply with quote
Kjekt å få prosjekta fram frå støvhaugen igjen og jobbe litt. Skal bli godt å få bruke bilen litt. Har ikkje hatt en challenger med skilt på snart fem år....har jo hatt både cuda og et par challengers på lager....men no skal det på veien litt Moparjern snarest Laughing
Hadde vore stas å fått komt seg på et mopartreff igjen og hilst på folket ja. Lenge sida sist.
Her er jo 14 E-bodybiler innafor en god times kjøretur i området heime. Har vore nevnt å ta en "E-buddies" cruising til sommeren Wink
PostPosted: Tue Oct 28, 2014 10:23 pm    Post subject: Vinterklar Reply with quote
Klar til vinteren no...Satt i tørt lagerbygg med mulighet for litt småskruing. Litt elektrisk og interiør står for tur.
 Filesize:  62.29 KB
 Viewed:  19381 Time(s)
 Filesize:  43.44 KB
 Filesize:  55.91 KB
 Viewed:  19384 Time(s)
Page 21 of 21
