1970 Dodge Challenger
PostPosted: Wed Nov 15, 2006 7:05 pm    Post subject: 1970 Dodge Challenger Reply with quote
Litt fakta fra salsbrosjyra:
The Challenger T/A's street version (A53) incorporates the following chassis and engine components as standard equipment:
Engine, Special 340 6 BBL. with modified block, special cylinder heads, and modified valve train (E55).
Rear Axle, 3.55 ratio 8-3/4 with Sure-Grip (D91)
Transmission, Special 4 Speed Manual with close ratio gears (D21), or Torqueflite Automatic (D34)
Exhaust System, Special low restriction dual exhaust system located ahead of the rear axle. Trumpet type exhaust outlets are to be mounted under the body side sills just ahead of the rear wheels
Brakes, Power disc brakes front and 11" diameter rear drum brakes with brake components selected for optimum braking
Suspension, Rallye suspension with front and rear sway bars and heavy duty shock absorbers
Steering, 24:1 manual
Tires, Raised white letters E60x15 front and G60x15 rear (U01) with a collapsible spare tire (W34)
Wheels, 15x7 black painted steel wheels with hub caps and chrome trim rings
To further augment its distinctive appearance, the Challenger T/A offers the following body feature as standard equipment:
Hood, Black fiberglass performance hood with carburetor air intake scoop (N94). Two front hood pins will be installed.
Body Configurations, A unique black tape teatment will extend along the upper portion of the front fenders and doors. It will terminate at the quarter panel and will feature a "340 Six-Pack" callout. A rear mounted antenna is supplied when a radio is ordered. A black painted grille (same as R/T), a new "duck tail" rear spoiler, a left coloured remote control racing mirror and a pop opening locking type fuel filler cap are additional standard appearance items.
Also available on the Challenger T/A are the following special options:
- Quick ratio power steering (Sales code S74)
- "Chin Whisker" front spoiler (Sales code J78)
- Quick ratio manual steering (Dealer installed)
- Four wheel disc brakes (Dealer installed)
The following options will NOT be available with the Challenger T/A:
H51 Air Condition
B11 Heavy Duty Drum Brakes
B41 Disc Brakes
M91 Luggage Rack
A45 Front and Rear Spoiler Packages
J81 Rear Spoiler
A35 Trailer Tow
T86, T87, U82 Tires
A05 Exterior Decor Group
V6, V7, V9 Body Tape and Bumble Bee Stripes
W11, W13, W15 Wheel Covers
W21, W23 Road Wheels
W08 Conventional Spare
A04 Basic Group
D13 3 Speed Manual Transmission
S15 Extra Heavy Duty Suspension
N88 Automatic Speed Control
A31, A36 Axle Packages
V50 Vinyl Side Protection Moulding
A66 Challenger 340 Package
For fleire bilder og spesifikasjoner sjå hovedsida under månedens bil for mars i år.
Spør meg gjerne om du lurer på noko rundt modellen Challenger T/A eller søstermodellen Plymouth 'Cuda AAR.
mach1frh
PostPosted: Wed Nov 22, 2006 10:06 am    Post subject: Reply with quote
Meget pen bil du har der Cool . Kjekt å lese om andre biler fra vårt langstrakte land Smile
1972 Plymouth Duster
PostPosted: Fri Feb 02, 2007 7:02 pm    Post subject: Reply with quote
Var ute og testa BF Goodrich Radial T/A dekker på snøføre i går, det var så fint vær. Rolling Eyes Unnskyldning Wink
Fungerte bra så lenge eg huska å bremse før svingene Idea
 Filesize:  67.62 KB
 Viewed:  30030 Time(s)
PostPosted: Fri Feb 02, 2007 7:08 pm    Post subject: Reply with quote
Ja og de gærne har det fortsatt veldig godt...he,he,he Smile
PostPosted: Fri Mar 09, 2007 2:05 am    Post subject: ta Reply with quote
hei
fin bil.har alltid likt ta challengeren.lagde en clone som er på lillestrøm no.gul med sort vinyltak.har alltid likt vinyltak på challengeren.skal bygge om rt/se'n min til TA utseende.såg reportasjen din i amcar.bra skrevet
mvh runar
PostPosted: Fri Mar 23, 2007 7:07 pm    Post subject: Re: ta Reply with quote
mr.mopar wrote:
hei
mvh runar
Takk for det Very Happy
Blir spennende å sjå bilen din ferdig også og håper du får med deg Power Touren til Rättvik.
PostPosted: Tue Apr 15, 2008 11:23 am    Post subject: Reply with quote
Fortsatt skiføre her. I April går det å kjøre godbilen til fjells og kombinere med ein skitur Very Happy
 Filesize:  183.07 KB
 Viewed:  28922 Time(s)
 Filesize:  193.84 KB
 Filesize:  172.59 KB
 Filesize:  216.82 KB
PostPosted: Tue Apr 15, 2008 1:08 pm    Post subject: Reply with quote
fine bilder.funker med amcar på vinterføre ja.
husker for masse år siden e va ute og kjørte på en lørdagskveld med bruksbilen.plutselig så daua den ut.ringte til en kompiss som kjørte drosje og ble heimkjørt.hmm,tidlig og ta kveld syntes e.kosta ein halvmeter snø av challengeren,starta opp og dro t byen igjen på fint vinterføre.gikk ein halvtime så kom purken og spurte om e va ute og kjørte i fylla.hehe.e måtte blåse for og overbevise dem.d va ein nabo som hadde ringt og sagt i fra at d va fyllekjøring på gang.jett om ho aldri får reparert vaskemaskina si hehe.e e den eineste hvitevare reperatøren i byen.hehe
MLcuda
PostPosted: Sun Oct 12, 2008 8:59 am    Post subject: Reply with quote
Hei er det noen som husker år og nummer på amcarbladet med repotasjen på denne fine bilen Very Happy
PostPosted: Sun Oct 12, 2008 9:51 am    Post subject: Reply with quote
tror d var nr.1-2 eller 3 i 2007 men regner med at han roar kommer med rette nr.
PostPosted: Mon Oct 13, 2008 8:17 pm    Post subject: Reply with quote
#1-2007 stemmer, ja Wink
PostPosted: Fri Dec 05, 2008 2:14 am    Post subject: Reply with quote
nydelig bil du har.., kunne ha drept for en i den stand som din er.. Very Happy
forresten sporty gjort å lufte den på vinterføre.. Very Happy
PostPosted: Sun Sep 27, 2009 7:36 pm    Post subject: Reply with quote
Vaska og voksa klar til vinterlager nå. Måtte bråbestille ein PKK-kontroll også sida den skal inn seinest i januar. Håper den går greit så er det bare å stue den unna etterpå Smile
PostPosted: Sun Sep 27, 2009 9:35 pm    Post subject: Reply with quote
Nydelig bilde... Exclamation Exclamation Very Happy
PostPosted: Fri Feb 12, 2010 10:41 am    Post subject: Reply with quote
Hei Roar,
jeg var inne på månedens bil mars 2006 og leste om den fine bilen din.
Men når jeg klikket på bildene dine ble jeg sent til forsiden til WPC, er det bare på min maskin eller er ikke bildene lagt inn?
