lADDNINGSPROBLEM
danne
PostPosted: Sun Aug 15, 2010 7:36 pm    Post subject: lADDNINGSPROBLEM Reply with quote
HEJ JAG HAR ETT UNDERLIGT PROBLEM MED MIN PLYMOUTH SATT 69. JAG MÄRKTE ATT DET GICK UT 17-18 VOLT TILL BATT, TÄNKTE ATT DET ÄR VÄL BARA ATT BYTA RELÄ KÖPTE ETT NYTT OCH SATTE DIT MEN ICKE ,SEN HÖRDE JAG ATT MAN MÅSTE JORDA RELÄT ORDENTLIGT SÅ JAG KÖPTE ETT NYTT OCH FIXA ORDENTLIG JORD MEN I HELV INTE DET VERKAR SOM RELÄERNAGÅR SÖNDER HAR HITILLS SKUTIT 5 RELÄER BÖRJAR BLI SMÅTT IRRITERAD HOPPAS NÅN HAR NÅGON ANING. Shocked
Dart270
PostPosted: Mon Aug 16, 2010 10:09 pm    Post subject: Reply with quote
Bruker du mekanisk eller elektronisk rele?
Hvis du har en nyere og kraftigere dynamo,
og det orginale mekaniske releet så går det galt.
1968 Dart 270 2 drht
danne
PostPosted: Tue Aug 17, 2010 5:21 pm    Post subject: Reply with quote
JAG HAR ELEKTRONISKT RELÄ OCH HAR HAFT GENERATORN KOLLAD PÅ VERKSTAD INGET FEL PÅ DEN.
norwayCharger
PostPosted: Mon Sep 06, 2010 6:27 pm    Post subject: Reply with quote
Se etter på dynamoen.
Har vært borti at isolasjonen på kontaktene ikke er bra, slik at de går til jord.
68 Charger RT 440
